wont start and tried everything i can think of
Old Nov 2, 2010 | 04:49 PM
ladiesman2684's Avatar
Default wont start and tried everything i can think of
I got a 96 camaro z28 and when i go to start it it does nothing. no sounds or anything. i have replaced the starter and selenoid, ignition module and coil, ignition switch, all the fuses are fine. I need some ideas. anyone got any?
Old Nov 2, 2010 | 05:00 PM
Massey's Avatar
is your security light blinking? If so it is your VATS system, sumtins wrong!!
Massey
Old Nov 2, 2010 | 05:33 PM
which light do you mean the one in the middle of the dashboard or the one buy the gauges? if its the one by the gauges it is not. any other ideas.
Old Nov 2, 2010 | 06:38 PM
1augapfel's Avatar
The security light reads "SECURITY" and it's located between and above the voltmeter and oil pressure gauges.
Is the car stick or automatic?
Old Nov 2, 2010 | 07:32 PM
Cammy 3.8lV6's Avatar
If you sit there and keep turning the key does it start?
I'd definitely clean all your battery connections with a wire brush to make sure they are spotless clean and tightened properly if you haven't yet.
When I start my car and turn on the ignition my security light on the dash blinks once and then goes away - if that light keeps coming on at you or stays on it might be the key chip.
Old Nov 3, 2010 | 08:03 AM
no the security light goes off and its not the battery. i can start it if i short the starter selenoid.
Old Nov 3, 2010 | 09:43 AM
test the small wire on the starter when the key is turned to the start position. if no power you have a bad wire from the switch or a bad swich.
Old Nov 4, 2010 | 03:45 PM
chewybacca11's Avatar
What about a relay?
Old Nov 4, 2010 | 03:47 PM
I would take a voltmeter and test the connection on the starter to see if it's getting power when you turn the key.
Old Nov 6, 2010 | 12:42 AM
thanks for all the advice but i got it fixed. it was the clutch starter switch.
