Wipers
I believe there is a fuse in the box on the side of the dash as well as a wiper motor. Usually it is a fuse. I don't have the manual right now but if you take the plastic piece off the side of the dash, it should show which fuses go to what. Also, there is a fuse box under the hood that has fuses and relays in it.
the wiper motor is under the hood, up in the corner on the driver side by the hood hinge. u have to take the cover off thats under the wipers to get to it. pita. there is a circut board on the motor that goes out to. i changed both mostly cause its such a pita. could also be fuse or the wiper switch itself. now thats an easy change.
