Windows not working on 95
Old Aug 8, 2013 | 07:59 PM
Camaroforlife's Avatar
Default Windows not working on 95
So I bought my 95 Camaro in an auction.
Windows didn't work so I pulled the panel off and the wires are all cut and the connector piece is missing.. >.>
The window motors work
I bought a express down module for another 95 and never used so I have a new one in the car.
I also bought new window switches
there are wires coming from battery and window motor like someone jerry rigged it. I took all that out and threw it away (fire hazard!)
Where do I start? I tried to reconnect the correct wires to the corresponding pins and nothing.. /; Maybe i'm doing something wrong A Little advice please! & if you want pictures of what it looks likes I will post them tomorrow!
Old Aug 8, 2013 | 08:24 PM
see if this helps, from 93 book should be the same
https://camaroforums.com/forum/lt1-l...25/#post639865
Old Aug 8, 2013 | 09:43 PM
also found this
Old Aug 8, 2013 | 10:21 PM
have you seen shbox good info, look in electrical. may also be some harness pictures
4th Gen LT1 F-Body Tech Aids
Old Aug 9, 2013 | 11:16 AM
I noticed the radio is connected directly to the fuse box would that suggest a problem with the R.A.P module ? (windows and radio must of went out ?)
Old Aug 9, 2013 | 11:45 AM
that would be a good first thing to look at thats for sure.
Old Aug 9, 2013 | 12:39 PM
I rewired everything the correct way about to hook it to the switch and see if it works if not.. It might be the R.A.P Would the interior lights and stuff still work if it was the R.A.P?
Getting no power to the fuse
Maybe bad solder points in the B.C.M?
Going to pull out the bcm and check the connections in it
Old Aug 9, 2013 | 03:14 PM
95 doesnt have a BCM? O.O I cannot find anything anywhere about it
my key has a chip in it so it must have a bcm.. ? (
back to wondering about the R.A.P and express down..
Old Aug 9, 2013 | 05:16 PM
no i dont think obd1 cars had the bcm. have you downloaded the factory manual. brb only have the 94 or the 96 books, 94 would be the closest to what you have, in 96 they chaged to obd2. https://camaroforums.com/forum/camar...d-views-73894/
Old Aug 9, 2013 | 06:49 PM
Thanks for the help craby! You would never guess how simple it was haha! I just ran a wire to the fuse to give it power and hey! PRESTO! they work!! Whoever cut up all the wires and stuff simply would of just put power to the fuse.. :P
