Window regulator rivets
Old 08-07-2011 | 01:57 PM
burning camaro's Avatar
Cool Window regulator rivets
Ok every one i have a 97 camaro rs i am fixin to replace the window regulator an need to know what size rivets i need to get to put it all back together like to have it all before i start the replacement any info would be great thank you
Old 08-07-2011 | 02:08 PM
BasicConcepts's Avatar
Technical User
i use nuts and bolts there much easier
Old 08-07-2011 | 05:10 PM
Phalen123's Avatar
Use nuts and bolts definetly but are you sure its not just the window motor that needs replaced? That's a much more common issue, also!!! Important
Use a sharpie around where every adjustable bolt/anything there is on that window panel and line it up when you re apply the regulator or they will never line up right again
Old 08-07-2011 | 07:18 PM
hevymetalg's Avatar
I second that^^^^^ it's prolly the window motor and nuts and bolts come with that.
Old 08-07-2011 | 08:20 PM
window regulator bracket takes a 1/4" diameter peel- type rivets. napa part number 665-2438 need a extra large pop gun to do it. better off to stop by the gm shop or a body shop and pay them a couple bucks to pop em for ya.
Old 08-08-2011 | 09:50 PM
0k thanks for the info its definely the regulator window track is all wore out and window roller is broken or atleast i beleave there called rollrs any way bought new regulator with motor from rock auto parts
Old 08-08-2011 | 09:55 PM
Technical User
i use 1 inch 3/8ths carriage bolts then after i tighten them down i go through with the cutting wheel and take off the extra bolt
Old 08-09-2011 | 07:57 AM
ok thank you i will make sure to do that
Chaotic94
02-04-2015 11:50 AM
vanquishfist
12-20-2011 10:42 PM
Kamaaina64
02-19-2011 08:13 PM
MartineZ28
06-18-2010 11:12 PM
TBenner80Z28
03-29-2010 08:53 AM
