Who knows how to Install egr valve. 1994 camaro v6. Help me thanks.
Alright your saying I can travel awhile on full to half. But half to empty 4 times faster. I think I understand what your saying. Thanks for helping.
If it helps, I think at full I can go about 310 Miles. I have the same car as you. I went to 300 before fill up (didn't wanna run outta gas a second time), and I averaged about 19.5. So Id assume you can hit around the vicinity of 17-20. Of course thats with conservative driving. As for a code reader Id search around this site.
Check Engine Light OBD2 OBDII scan tool OBD
A cheap $30 code flasher won't work on your car. You will need a OBDI scanner, or a scanner that reads both OBDI & OBDII.
Let me know what code you have. Auto zone usually can read a code for free. I think you may have a leak near the fuel pump. I have something similar going on, found crap in the EGR replacing it did not fix it. Cleaning it might help.
Also my tank is exactly what the others are saying, I get over 200 miles on the first half and maybe 100-125 on the second half.
#20
id suggest throwing a lotta cardboard under the car, locate where its leaking from, and keep pinpointing it from there. Plus you might be able to look and the cardboard and smell if its gas, oil, etc.
