white lights??
white lights??
do the headlights for a 1995 camaro have a replaceable bulb in them? or are they a sealed headlight that you have to replace all-in-all? because i want to get high and low beam white lights like on the bmw's.
Technically they're sealed, that said, there is a separate bulb inside, but you can't purchase just the bulb (ya, it's weird). People have fabbed up HID lights (I'm pretty sure 02StanGT did this), but you cannot purchase just the bulb and have it drop right in.
You can remove the bulb and replace it, but the way of holding the new one in is kind of.... lets call it redneck engineering. You basically use a silicone to "glue" the new bulb in place of the old one after you force it out.
I explain both ways, in my write up in the Exterior section. You can do like Music said, or get some housings from www.eurolamps.com. Those housings use a clip to hold the bulb in. Either way you do, 9006 bulb is for the lows, and 9005 bulb for the highs.
Yeah, I changed mine out to the Silverstar Ultras, sealing them with silicone.I did both the low and high beams. Works perfectly, not hard to do, and quite a bit brighter then the stock headlights. I recommend it!
pojo1988
08-27-2017 09:35 PM
