Where do I jack up my camaro
Everyone puts jack under rear axel even tho it's not a good spot .You risk bending the cover and causing a leak,put a rag between diff and jack pad and you will be fine.
Block front wheel,make sure car is level,start jacking,either put jack stands on axels,or put on subframe in front of rear tire,the same position that the spare tire jack would go as per you're manual.
I also put ramps or wood under a tire just in case,you can never be to safe under 3000 lbs of metal.
