Where is the asr fuse located for 1997 Z28
Old Oct 31, 2009 | 12:32 AM
Eureka's Avatar
Default Where is the asr fuse located for 1997 Z28
I have no fuse panel cover with a diagram. I tried google but nothing. If any one has a diagram to post it would be appreciated..My ASR light is on, on the dash. From what I've read, if the fuse is out it will also turn the ABS light on too... This seems to be the answer to lights on the dash. Please help...
Old Oct 31, 2009 | 09:54 AM
x01660's Avatar
The Mustang Hunter
Hope this helps.
x01660
File Type: zip
Old Oct 31, 2009 | 01:47 PM
Eureka's Avatar
That does help, that is the underhood panel though. Is there one that goes to the fuses on the side of the dash board near the drivers side door?
Thanks!!
Old Oct 31, 2009 | 08:01 PM
x01660's Avatar
The Mustang Hunter
This is it and I don't see a fuse for ASR. Try to pull codes to see if there is something else.
File Type: zip
Old Nov 1, 2009 | 10:21 AM
Eureka's Avatar
Thanks brother!!! Awesome.. I'm gonna see under the hood and check them.. If not I guess pulling the codes as you suggested is the way to go.. Thanks again, very helpful....
izayuhgawd
Nov 21, 2011 09:24 PM
LT1sbc
Aug 21, 2010 03:29 PM
ladybridgeport
Apr 5, 2010 08:44 PM
ls1only
Jan 9, 2009 08:07 AM
