Whats a part list for a caliper bracket
Old Sep 23, 2011 | 03:04 PM
Pemolis's Avatar
Default Whats a part list for a caliper bracket
I'm replacing my rotor's when I get back from vacation on my 2000 Camaro. I believe my caliper is good, but my caliper brackets are bad (the reason really does not matter, I want to replace them).
Now I know Cardone has both front and back caliper brackets, but I don't quite know the names of the rest of the items that make up this part of the caliper assembly.
I know there is the caliper bracket, the front and rear are different ones.
There is the caliper pin that goes into the bracket (each bracket has 2 pins, so I would need to order 8).
There is also apparently some rubber stopper thing that goes on the caliper pin? I don't know what this is called.
There are also some small steel metal clips that goes on the end of the brakes.. Is there a name for these also? I just recieved the rotor's and brakes but there is no tiny clips.
Is there anything else I am missing here? I figure a 4 set would cost around 120 or so. Is that about right also?
Thank you in advance.
Old Sep 23, 2011 | 04:30 PM
TheRegulator327's Avatar
Pemolis,
All of the components that comprise the brake caliper are listed at gmpartsgiant's parts listing: 2000 Camaro OEM Front Brake parts
Note that the rear brake components are also listed in the 'components' drop down tab located at the top part of the page. Happy hunting!
mab6680
Mar 10, 2014 07:49 AM
socalrs
Feb 6, 2012 04:55 PM
DarkKnight
Sep 22, 2010 09:14 PM
The Corvette Doctor
Jul 17, 2010 11:38 PM
350rs
Jun 1, 2009 05:26 PM
