what kind of power does this have?
This is a 97 Z28, Red with charcoal leather. 93,xxx miles, A4 355cid
Mods: Engine: 97 block, built by Kim Barr in garland, tx 355 New stock crank, JE Pistons Crower rods arp rod bolts Lt1 heads, ported Lt1 manifold, port matched 1.6 crane rockers comp pushrods comp r lifters lt4 hotcam lt4 valve springs ported throttle body Tranny: Built 'stage 3' tranny by local tranny shop. Supposed to be good for 650 rwhp. 10inch 3200 Art Car verter Trans go shift kit BM tranny cooler Rear: stock 3.42 with zexel posi Suspension: BMR tubular weld in subframes Hotchkis boxed LCA's and brackets Hotchkis STB Misc: meziere street elec. water pump Mac Midlength headers and Y stock catback with cutout new starter new opti MSD wires Fuel: Walbro 255 lph intank aeromotive FPR MSD ignition Brakes: Powerslot rotors on back stock up front new eagle pads any idea on what this would run? its for sale right now and woundering what it would run. it does need a tune though. |
RE: What will this run?
All those mods and a stock rear? Hmmmmmm ;)
it doesnt sound stock at all. ive went and test drove many other z28 and none of them sounded like this one. ill talk to the guy if my loan goes through. i probably shoulda asked him for receipts and what not.
Sounds kind of fishy too me man. [>:]
I would say low 13s easy with good ruber probaly run side by side or a little ahead of the mildandnear stockLS1 guys, Maybe high 12s with slicks and gears
why does it sound fishy?
ill said low -mid 13s stock ls1 area |
my guess would be..... fast... no... really fast
I have a 383 with basicly that same stuff and a lt1hot cam. It ran 12.9 @ 109 when the track temp was 111 and it was 103 outside in phx AZ. I also have 315 35 17 bfg drag radials. So depending what your compression is you could be right around there.
Compression would probably be stock. Crank is stock and cylinders haven't been bored over. The only thing that worries me is the high stall converter for street driving.
sounds pretty good to me. would i be able to buy some kind of electronic lockup for the converter?
