well my car needs some parts
Old Aug 21, 2007 | 04:01 PM
1994greenchevy's Avatar
Default well my car needs some parts
My car lets out blueish white smoke and i was told that it was buring coolent and that means that there is a gasket gone or one of the heads were warped. It also knockes when it shifts, it will shift to second and will knock for about 2 seconds and then stops, then it smokes.what does that mean? It smokes when I floor it to.
About how much would stock heads be? and about how much would gaskets be?
I feel like i have posted this before i just can't remember. Sorry if it is a repost.
Old Aug 21, 2007 | 04:09 PM
meteoralp45's Avatar
Default RE: well my car needs some parts
does it smoke constantly? and are you in an auto or a manual
Old Aug 21, 2007 | 09:02 PM
it is a auto and no it smokes for like 2-10 seconds
Old Aug 21, 2007 | 09:08 PM
95slvrZ28's Avatar
White smoke is typically water getting into the cylinders and comming out as steam, it's typically caused by issues with the heads. On the other hand, if it's a blue smoke, that's typically oil leaking into the cylinders, which isn't an uncommon problem, most of the time is a leaking ring and not something that's too big of a deal unless the car is using a lot of oil.
Old Aug 21, 2007 | 09:22 PM
ohh it smells horrible to. it smells like sulfer/rotten eggs
Old Aug 21, 2007 | 09:25 PM
badinfluenceRS's Avatar
sounds like the trans is slipping...
if it was a head gasket the smoke would intensify the longer the car runs, where if it's just on start up your just burning some oil, i would worry about the tranny more than the little smoke burst at this point
Old Aug 21, 2007 | 09:31 PM
not trying to be a smart alec but where didtranny come from?
Old Aug 21, 2007 | 09:34 PM
well u said about your car shakin in second gear...so thats where that came from, but as far as the smoke, i second what they said, and alot of chevys have problems blowin white smoke from water on start up, older ones,
Old Aug 21, 2007 | 09:41 PM
ohh i said knocks. I see where you got that from. ok sorry about that.
Old Aug 22, 2007 | 03:55 AM
RatedZ's Avatar
ORIGINAL: 1994greenchevy
It's not too tough to find stock heads for an LT1. A lot of people sell them off for about $300 per set if they still have them. Also check with some machine shops, because normally machine shops will just junk them, or sell them off at a very discounted rate. Since the LT1 heads really aren't that great, there isn't a huge number of people looking for them.
