The weather is Beautiful, should I risk getting stranded? Fuel pump question
Old 05-10-2012, 05:54 PM
DashingDaryl's Avatar
Default The weather is Beautiful, should I risk getting stranded? Fuel pump question
I bought my 2000 3.8 with 84,000 miles. It has 86,000 now.
Today I picked it up from the painter's and it was on empty with the Check Gages light on. I pulled into the closest station and got 4 gallons.
Driving down the freeway the car cut out for a fraction of a second. It did it maybe three times in a 40 minute drive. I made 3 stops and starts during that time.
Is this a sign of a failing Fuel pump? Is the average life really only between 80 and 100K miles? Could I have just bought some bad gas? I changed the fuel filter two weeks ago.
I checked under my back carpet and no access hole has been cut.
Could the engine cutting out be due to a bad A/C Clutch? (read my other post)
What do you think and what would you do?
Old 05-10-2012, 10:17 PM
The first thing you should do is to check the fuel pressure per the factory service manual. Running empty can cause the pump to overheat and break down. Testing the pressure under load should give a good indication of the state of the pump.
Old 05-11-2012, 08:07 AM
androzer's Avatar
when the car is empty of fuel, the check gages light goes on?
Old 05-11-2012, 08:31 AM
And the light made him check his gas gauge.
Old 05-11-2012, 12:16 PM
Originally Posted by z28pete
check the fuel pressure per the factory service manual. Testing the pressure under load should give a good indication of the state of the pump.
Hey thanks. I appreciate you pointing me in the right direction.
I don't have the service manual, can you sum up the procedure for me?
I assume it is uses a pressure gage on the fuel rail both at idle and under load (means during acceleration). Is that correct?
Can you tell me what the pressure should be?
Old 05-11-2012, 05:40 PM
androzer's Avatar
and how many miles do u have or KM as soon as the light is on?
pcarollo
09-30-2014 10:08 PM
cjgordon117
09-25-2012 10:19 PM
pcarollo
07-05-2012 01:37 PM
91camaropalmer
12-19-2009 05:03 PM
camarofreak1990
06-26-2009 12:48 AM
Quick Reply: The weather is Beautiful, should I risk getting stranded? Fuel pump question
