water temp gauge dosnt work
Old Feb 23, 2014 | 06:57 PM
CarolinaCamaro's Avatar
Default water temp gauge dosnt work
i have a 1999 v6 camaro. the water temp gauge is not working. i bought it this way. i replace the cooling temperature sensor thats under the throttle boddy already and it did nothing. what do i do?
Old Feb 23, 2014 | 07:17 PM
i thought it was on the driver side head by #1 plug
Old Feb 23, 2014 | 07:24 PM
i found a thread that said there are two. they talked about the one that i replaced thats under the throttle body and that there is one at the head like ur talking about. i couldnt find the one near the head. do i have to take anything off to find it?
Old Feb 23, 2014 | 09:41 PM
im not finding it either. test the sensor to see if its working. use ohm meter.
∫C ∫F Ohms
100 212 177
90 194 241
80 176 332
70 158 467
60 140 667
50 122 973
45 113 1188
40 104 1459
35 95 1802
30 86 2238
25 77 2796
20 68 3520
15 59 4450
10 50 5670
5 41 7280
0 32 9420
-5 23 12300
-10 14 16180
-15 5 21450
-20 -4 28680
-30 -22 52700
-40 -40 100700
Old Feb 23, 2014 | 09:52 PM
test the sensor i replaced to see if its working?
Old Feb 23, 2014 | 11:49 PM
yep see what the sensor is saying to your system. if you have access to a scanner and it has ability to see readouts you can check and see what temp your computer is seeing.
Old Feb 24, 2014 | 08:16 AM
I do believe your engine has a combination temperature sensor/temperature gauge sending unit, where other engines have separate ones for the computer and for the gauge. Could be your gauge is just bad, or there's a broken wire leading to the gauge cluster. Does the gauge do nothing at all, or just inaccurate? Does your cooling fan go on right away, or is that working normally?
Old Feb 24, 2014 | 05:54 PM
yea thats what i heard. i replaced the sensor and i didnt fix it. i cant find the sending unit they say its near the heads on driver side. all the other gauges work in the cluster. the temp gauge is dead and dosnt move at all. and my cooling fan works normal. it dosnt come on when i start my car.
camaro396
Aug 9, 2015 06:29 AM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
bizarre660
Oct 4, 2010 09:48 PM
boatman2089
May 30, 2010 07:18 PM
josh95camaro
Oct 9, 2009 10:15 AM
