Water in Front Signal Housing, Solution?
Old 04-26-2011, 06:29 PM
libertyforall1776's Avatar
Question Water in Front Signal Housing, Solution?
Anyone else have water entering your front Running Light/Turn Signal Housing?What solution did you come up with? I have to imagine water is entering through the seal around the bulb -- not sure where else it could leak in. Too bad it's a PITA to remove the housing -- else I would have done more already.
Would it be a bad idea to drill a hole in the bottom of the housing to prevent this in the future?
Old 04-26-2011, 06:58 PM
usually its the front lens seal. you may be able to put some water in it after its out and see if it leaks out anywhere other than the bulb hole.
Old 04-26-2011, 08:44 PM
I have used the drill method several times with no ill effect. Nothing bigger than 1/16" at lowest part of lens.
Old 04-26-2011, 09:06 PM
Phalen123's Avatar
Take it out fill it up with rice let it sit overnight drain it out
Old 04-26-2011, 09:10 PM
^^^^ whattt????
Old 04-26-2011, 09:25 PM
Chevy101's Avatar
Where I work I have access to an industrial heater so I removed the lens and let it dry then I used plumbing silicon around the lens and it turned out I was missing the gasket for the turn signal
Old 04-26-2011, 10:24 PM
Yea, heard about the rice trick... So who has the most expedient way to remove the housing? ;-) It's a contest -- shortest removal procedure that does not involve destroying things wins!
Old 04-27-2011, 08:06 AM
Chevy101's Avatar
Go in from the top. Remove the headlight and it will take you no joke no more than 5 min to remove the housing
Old 04-27-2011, 11:43 AM
^ Hmm, did not look like enough room -- heck, I broke skin going in from the top just trying to replace the main bulb...
pcarollo
05-21-2015 02:50 PM
lawboy19
09-13-2011 08:32 AM
Chevy101
11-23-2010 02:06 PM
johnnythehmc666
11-10-2010 05:06 PM
Saint_Ali
07-07-2007 06:53 PM
Quick Reply: Water in Front Signal Housing, Solution?
