VSS. No speedometer. Hard cold start.
Old 01-07-2018 | 02:21 AM
Danny Lee Brehm's Avatar
Default VSS. No speedometer. Hard cold start.
VSS. No speedometer. Hard cold start.-img_0186.jpgI have a 1995 camaro 3.4l base model. Pack Rats chewed the wires on the harness junction. I hard wired the wires. No shifting. Seems in limp mode. Check engine light is on. Anyone have a solution. I had this vehichle running and have installed 3 VSS sensors. Also rewired the sensor above the starter. no luck.
Attached Thumbnails VSS. No speedometer. Hard cold start.-95-camaro-wires.jpg
Old 01-07-2018 | 08:47 AM
have you downloaded a factory service manual yet. i see we have a 95 link here https://www.mediafire.com/?40mfgeoe4ctti
Old 01-07-2018 | 11:33 AM
Have you pulled the codes yet? It might give you a clue. Speed sensor by itself won't put the car in LHM. When the speed sensor does not work then the PCM does not know the car is moving. The car not moving is not an error.
I had a 96 with this a completely failed speed sensor a while ago, no check engine light at all. It just would not come out of first gear.
rs657f
11-26-2015 11:45 PM
Dakota Bogart
09-03-2015 10:36 PM
Tommyboyink
10-20-2011 01:11 PM
PERSHA25
06-23-2009 06:18 PM
BEBEAU02
82-92 V8 Tech
01-19-2008 06:37 PM
Quick Reply: VSS. No speedometer. Hard cold start.
