Valve Cover Replacement Questions
Old 04-25-2012, 08:42 AM
DDRDiesel's Avatar
I'd say check the head gasket (If you don't feel comfortable ripping the engine apart to troubleshoot this, you can always take it to your local mechanic). I have a 2003 Dodge Ram that suddenly started spewing out white smoke, which eventually got worse. Took it in and the head gasket was blown. You would also benefit from checking the coolant reservoir and antifreeze level in the radiator. A coolant leak could explain the smoke, as well as the coolant gauge level not moving
Old 04-26-2012, 04:34 PM
voxeltoxin's Avatar
I dont know what was causing those problems but they have both went away now. If they come back I will do some more investigating.
voxeltoxin
12-14-2014 02:24 PM
mezzyshredder
06-04-2012 07:49 AM
Sungeun
07-07-2010 06:29 PM
lowend
70-81 V8 Tech
12-11-2008 06:54 PM
mstephens20
03-26-2008 09:23 AM
Quick Reply: Valve Cover Replacement Questions
