V6 issue low circuit
Old Jul 13, 2020 | 03:30 PM
Matthale's Avatar
Default V6 issue low circuit
Got a96 3.8 5spd low circuit maf an tps.crank no start.fuel rail pressure.has pressure probably low.have fire.havent checked all wires.replaced maf.plugs&wires air flow sensor.
Old Jul 13, 2020 | 06:54 PM
Hotchkis make a replacement cross brace that allow many of the aftermarket exhaust fit.
https://www.camarocentral.com/1967_1..._p/sus-610.htm
Old Jul 13, 2020 | 08:29 PM
check battery to make sure your getting around 12 volts. check grounds, check wire connections.
Old Jul 13, 2020 | 08:31 PM
also if you haven't already download factory service manual here 1996 svcman https://www.mediafire.com/?40mfgeoe4ctti
Matthale
Jul 13, 2020 03:13 PM
amwatchinya
Jun 24, 2011 02:29 PM
cavballer97
Apr 19, 2009 01:38 PM
Y2KCamaro
Oct 18, 2008 04:28 PM
