Update: Still no spark! 96, V6 3.8L.
Old Oct 19, 2010 | 04:16 PM
  #31
Massey's Avatar
Those silver cogged things in there are the reluctor wheels. The outside one is the 18X and the inside is the 3X.
Massey
Old Oct 19, 2010 | 05:15 PM
  #32
AnalyzeFaith's Avatar
Thanks a lot guys. I guess I am going to have to get my mechanic to do that for me, I dont have a Harmonic Balancer Pulley and I dont want to end up buying the wrong one... I hope this fixes my problem.
Old Oct 19, 2010 | 05:30 PM
  #33
Massey's Avatar
Yes you do!!! that is the big pulley in the picture on the left side. You do need the puller tool and most autopart stores carry them. Ask them for the Harmonic ballancer puller for a Series II 3.8L engine. For good measure tell them it is out of something like a 2001 bonneville. (most camaro and firebirds use a different pulley that does not need a special tool)
Massey
Old Oct 19, 2010 | 06:21 PM
  #34
I meant to say puller! LOL! And I'll def try that out, do they charge to loan tools?
Old Oct 20, 2010 | 11:51 AM
  #35
96 3.8L Texas's Avatar
Security system lock out?
Old Oct 21, 2010 | 10:41 AM
  #36
Massey's Avatar
No the engine cranks over. If it was the security system the engine would not crank.
Some part stores rent them but this pulley has some odd thread that is not very common. Sorry I cant remember what the thread was but it is odd.
Massey
Old Oct 21, 2010 | 10:45 AM
  #37
yah i had to take the original bolts out and run to the hardware to get some that would work with my puller. if i remember right there metric.
Old Oct 21, 2010 | 07:31 PM
  #38
microkid's Avatar
March 2011 ROTM
Technical User
when i pulled the balancer off of darling's car, i didnt need a puller. i undid the bolt with a 1 inch socket and my impact gun and it slid right off the crank. it was the same for install. altough for the crank sensor, you shouldnt have to remove the balancer. there should be access if you undo the two 10mm nuts that bolt the p/s pump on and pull it off the mounting studs and hang it off to the side. should be plenty of room then.
now, have you actually checked for spark? also with darling's car, i noticed 1 wire in the plug going into the coil packs was slightly pushed out. when i reassembled it, her car had a code, something like high voltage primary ignition circuit, and would stall. i used a small bit of copper wire to make a temporary fix before i replaced that pin. since then there has been no issue. might be worth looking into
Old Nov 16, 2010 | 01:33 PM
  #39
Problem was the CKS, got it fixed and cranked right up. Did a full tune up, oil change, drove nice then randomly shut off while driving again... Its the SAME symptoms as before. I'm bumping this since I am having the same problem again and maybe some of you can help.
Old Nov 16, 2010 | 02:54 PM
  #40
Massey's Avatar
Does it drop out when it hits operating temp? If so it more than likely is an issue with your car going into closed loop. You could have another sensor that is not reading properly or at all and causing the failure. Also it may not be tripping a CEL if the computer does not have the time to run the diagnostics on that system before the engine dies. O2 and MAF could easily cause this, neither are cheap so I would not suggest throwing money at it to try and fix it see if you can find a flow chart like Liberty posts to track down the issue. L
Liberty do ya have a flow chart on this issue?
Massey
