trouble starting
Old Apr 14, 2013 | 04:28 PM
bcbarbie's Avatar
Default trouble starting
when I try to start car she starts to spit and stutter but doesn't start then when turn off ht keeps going!
what could be causing this?
Old Apr 15, 2013 | 12:28 AM
what year and engine? so it does run?
Old Apr 15, 2013 | 12:33 AM
If I read you right, the engine only starts once you back the key off? Sounds like it could be the ignition switch (located down lower on top of the steering column), not giving power to the ignition in the start position, but still does in the run position which lets the engine start while it's still zinging over.
Old Apr 15, 2013 | 09:44 AM
bcbarbie's Avatar
LT1 is engine 1994.
It actually doesnt start but still tries when in off position
Old Apr 15, 2013 | 10:12 AM
bcbarbie's Avatar
Maybe switch but I doubt it more like fuel or ignition . Sorta like timing out and pre detention ?
Old Apr 15, 2013 | 11:44 AM
how old are the spark plugs? opti?
Old Apr 27, 2013 | 09:33 PM
bcbarbie's Avatar
Spark plugs brand new
Old Apr 28, 2013 | 06:51 AM
hate to say this but the opti may be the problem
Old May 2, 2013 | 10:38 AM
bcbarbie's Avatar
Whats that
Old May 2, 2013 | 10:40 AM
bcbarbie's Avatar
The other day while trying to start it spit and sputtered trying but didnt start then a little tiny puff of smoke came out of top of engine WTF!!
