Transmission
Old Jul 15, 2007 | 03:16 PM
Reaper3000GT's Avatar
Default Transmission
I've been worrying about this, I have a 6 speed 97 SS and I was wondering if I were to shift into 5th gear but accidently shift into reverse thus dropping the transmission out of the car lol. But I was wondering if there is a saftey feature,.
Old Jul 15, 2007 | 03:18 PM
z28logan's Avatar
Default RE: Transmission
I'm pretty sure there's a preventive mechanism. If not, you can always cut out your reverse and save like one transmission to like each wheel.
Old Jul 15, 2007 | 03:33 PM
Yeah I thinking about getting one of those steel slot selecter things. So I can slam some gears .
Old Jul 15, 2007 | 06:21 PM
Lee Willis's Avatar
The construction of the synchronizers alone assures it is very unlikely to happen. Much more common and the cause of more than one blown engine and drivetrain is to shift into 3rd instead of 5th. Sort of ruins everything. AGain, the synchros tend to provent this -- they generally make the gear closest to synchornization by far the easier one to push into. But I have seen a car after the driver mistakeningly did 3rd instead of 5th at the redline in 4th. Ruined engine and trans.
Old Jul 15, 2007 | 10:14 PM
Thanks for the info everone
Old Jul 19, 2007 | 12:56 PM
evilhaserrors's Avatar
Ive got a 5 Speed 94' and I have been worried about slamming it into R instead of 6th...my dad has a 73 Stingray with a 6 speed (the only part of the car not stock) and thats how I learned to drive stick....so there is no way to get it into reverse at 100mph?
Old Jul 19, 2007 | 02:16 PM
95slvrZ28's Avatar
I belive the T56 has an electronic sylenoid that locks off reverse if the car is moving. I know for a fact that I cannot put my dad's Z06 into reverse unless the car is running and not moving foreward.
Old Jul 21, 2007 | 01:39 AM
azneau28's Avatar
any of you guys know where and how much it would be to rebuild a 6 speed
Old Jul 21, 2007 | 09:38 AM
See the sticky, in the 4th gen V8 section, on the T56 gear box.
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
