tire width
Old Feb 26, 2008 | 09:39 AM
Imperium's Avatar
Default tire width
I need new rims and tires, probably going for the z06 17"s which are recommended 275/40, will 275s be ok in the front or should I go for something smaller?
Old Feb 26, 2008 | 11:15 AM
02StanGT's Avatar
Default RE: tire width
I believe SS's wear 275s up front. I had some on my '97 back in the day. Had no problems.
Old Feb 26, 2008 | 11:18 AM
LT1RUNNER's Avatar
You had that wide of a tire in front?! I have 255's up there and they look good.
Old Feb 26, 2008 | 11:20 AM
02StanGT's Avatar
Yes. Not now, as I have a different '97.
Old Feb 26, 2008 | 12:00 PM
95slvrZ28's Avatar
I run 275's all the way around. That was OEM size for SS's, I don't have any problems with rubbing etc.
Old Feb 26, 2008 | 03:29 PM
importmd's Avatar
i also run 275's all around, no issues
Old Feb 26, 2008 | 07:12 PM
98ss4REAL's Avatar
275's in the front 315's in the back is the way to go i hook nice!!! o ya and get some nitto drag radials for the rear or any d.r if ya can
Old Feb 27, 2008 | 01:06 AM
95slvrZ28's Avatar
The only issue with 315's in the back is if you want to rotate tires you can only do left to right, and you have to pay a minimum of $200+ per rear tire if you don't want a crap tire.
Old Feb 27, 2008 | 07:59 AM
Imperium's Avatar
yeah I was wanting to do same size all around for that reason
ordered the 275s already
Old Feb 27, 2008 | 06:35 PM
98ss4REAL's Avatar
man ebay sells tires cheap and nittos will last a while unless u try and burn them up alot
CamaroKid16
May 5, 2008 06:39 PM
Solidus
May 2, 2007 07:15 PM
Z_TwentyEight
Mar 28, 2006 11:58 PM
PrinceCharmmin
Sep 3, 2005 10:02 PM
freshmanit
Aug 11, 2005 01:34 AM
