tire pressure 1/4 mile
Old Feb 7, 2008 | 05:32 PM
Z28 Kid's Avatar
Default tire pressure 1/4 mile
hey just wondering if my cars tire pressure really even plays a big factor in my 1/4 mile times. last time i ran i had around 27 pounds for more traction but my car spins the tires anyways. so would i be better off running with about 35 psi in my tires and just roll into it. cuz wouldnt i achieve a higher mphwithhaving more psi in my tires?
Old Feb 7, 2008 | 10:57 PM
95slvrZ28's Avatar
Default RE: tire pressure 1/4 mile
Trap speed is almost completely dependant on the amount of power the car has, launch has little to do with it, so don't expect higher trap speeds. That being said, what you really need to do is check the tire at various intervals to see where you get the widest traction patch and go with that PSI, maybe a little more because the sidewall will squat down on a hard launch. If you're spinning at the start, it sounds like you need to work on your launch technique, practice makes perfect.
v64thgen
Jan 5, 2012 03:31 PM
Dappled Apple
Jan 23, 2010 06:53 PM
aleksandr
Nov 29, 2007 12:03 PM
00camaro00
General Racing/Tech
Sep 25, 2007 12:13 PM
wwotr
Jan 13, 2007 07:21 PM
