Thumpig noise/feel when turning right.
Old Sep 11, 2011 | 01:51 AM
BasicConcepts's Avatar
Technical User
get your tires balanced could also be in your suspension or steering
Old Sep 11, 2011 | 02:25 AM
Xhifer's Avatar
I barely feel it on the steering wheel though, surprisingly.
Old Sep 11, 2011 | 09:29 AM
how do the rotors look, how do the brake pads look.
Old Sep 11, 2011 | 10:11 AM
Xhifer's Avatar
Pads has under 2000 miles and was resurfaced 2000 miles ago.
Old Sep 11, 2011 | 01:12 PM
vanquishfist's Avatar
Would it be possible to get this noise on a video? If it's a bearing, we could tell you right away.
I changed a noisy wheel bearing on my sister's car, and it didn't make any noise when spun with the wheel off.
Old Sep 11, 2011 | 02:45 PM
Technical User
You need usually need a load on the bearing to make a noise
Old Sep 11, 2011 | 03:47 PM
yep if its just starting to go its not easy to tell. mine was overheated on one side by a sticky caliper so i checked it and it turned easier then the other side so i changed it. figured the grease got cooked out of it. the other side has a smooth constant turn that took a little effort to turn.
Old Sep 11, 2011 | 05:48 PM
Technical User
take the wheel and caliper off and bolt down the rotor then shake that side to side up and down there should be NO play
Old Sep 11, 2011 | 07:01 PM
Xhifer's Avatar
Thanks for the help guys. It's impossible to get a soundclip of it. The road noise overpowers it on the videos. I have noticed the right side caliper is leaking a little brake fluid. Can that be it? When I jack up both cars and spin the front wheels. The left one will complete over 5 rotations, but the right side will do 3 and less and stop. I really can't tell if it's the brake pads still contacting or if its the wheel bearing.
Old Sep 11, 2011 | 08:49 PM
  #20
Technical User
brake pads make a constant noise unless the rotors warped either way by your description i dont think its the brakes try what i said earlier it works
