Those little clips that hold the window/lock cluster to the door
I took my door apart a few days ago to adjust the window, and one of those little clips that hold the window/lock cluster to the door won't stay on the cluster. It's not bent up, it just won't stay in the cluster- if I push it in, it p'tings off into the door handle and I have to fish it out. Is there a trick to getting it to stay? I'm tempted to superglue it in...
when i got my car the driver side had broke and then i was going thru the drive thru of mcdonalds with a buddy and another of my friends decided to jump but he landed on the door and the passenger side popped out... i got some hella strong glue and fixed it.. looks like crap but does the job.
This switch broke a couple years ago- the clips AND the cluster are relatively new, and all factory OEM components. Cheap GM crap, I suppose... I'll try the superglue tonight and see if that holds. If not, I'll mix up some epoxy. Either way, it should be hidden. Thanks guys!
