Test-N-Tune, X half a dozen!
Dont you have a home to go to little ****er.....guess he likes hanging around race cars.
Swapped the trans AN fittings to 90 bends, and got under the car and attached the lines. They were barely long enough at 10ft. Added a ground and am running a 12v+ turn on wire for the fan up front.
Hot wire relays, they need a ground, and plug into existing wiring to turn on, but both also need 12v+ from the battery so I will be running those up front as Im doing the fuel lines.
I had black carpet. The car is sorta charcoal/black. **** it I'm putting it in there anyway.
Mounted the catch can on the passenger fender, and test fit the intake. With a little plastic trimmed it went right in. Then I realized no way in hell the hood will close.....So back to the drawing board for intakes, the truck intake is OUT. Also, Ive decided to mount the vacuum block in that cubbie space where the wiper motor used to be on the drivers side.
Got the harness/PCM out. Install these into slots 22 and 23. They read the front input speed sensor on the 4l80e.
The purple connectors in this pic WERE my driver's side coil pack connector. Why these were spliced (by previous owner) onto this harness I have no clue. I cut the coil side off the coils before I sold the motor bc I knew the poor guy couldn't plug them into anything. I soldered him a regular connector (white ones seen here) so he could use any LS harness. I had a buddy cut me a harness side off a junkyard truck, so I needed to remove this goofy purple connector and replace with the correct one. All soldered and heat shrunk and we are in business. I had the purple ones just laying there so you can see them.
I got the harness laid on the motor and will start getting things plugged in soon. I'm gonna solve this intake dilemma by the end of the week and have a few things on order like vacuum line and oil pressure sensor since the truck version is different, my -10 line for the catch can, a few more fuel fittings etc. Got an update today from Huron speed, we are still 10-15 days out on the turbo kit due to a production delay. Rats.
Quick update, I was on the hunt for an intake and my buddy (thanks Randy C) had an LS2 laying around for cheap so I went and grabbed it. I decided to give it a "fast" type look and only paint the upper shell. Just went with the same graphite color i been using.
Had to use an alternative set of fuel rail brackets and trim my spacers down by about 1/3 but everything seems to fit nice. Also, I ordered the FAST fat orings for the bottom of the injectors since everything LS2 and later have bigger injector holes then LS1 stuff. 146020COR is the part number. 3 bar MAP sensor is in place, and the stock wiring is gonna have to be extended.
The black fittings are -10 for the catchcan to valve covers, along with matching -10 black nylon lined hose, and the rest of the fittings are the elbows to come off the rails, then random vacuum line, an exhaust reducer (more on that later) and the Honda alternator. Yep my daily is down so I will be fixing it instead of doing race car stuff.
Super fast delivery....this is the PCV delete model, no vent tube. 92mm.
But that intake has no provisions for a cable throttle body, what do you do? You make one, no other choice. Also, I installed a car oil pressure sending unit and attached the main vacuum line to the rear of the intake. After I swap the injector orings we are ready to do a final install on the intake. I've got the elbows on the catchcan in this pic, but until I see where the alternator is gonna end up I can't exact figure out the routing. Come on Huron Speed!!!!
Don't have a lot of pics this update but I did get some stuff done on my two days off. Basically I started with the intake, I scrapped my L shaped throttle cable bracket and made a new one that utilized the front two intake bolts instead of the previous one. It is also as far over as it can be to help keep the cable better lined up with the throttle body. After that I did the final bolt down of the intake, I added about 12 inches (solder and heatshrink) to the MAP sensor wires since it is now on the front of the intake, can see it right under the throttle cable. Ran the main vacuum line to the vacuum block that's where the wiper motor used to sit. I did have to grind the water pump, which i previously did not have to do for my fast 92 or 102 setup. The entire harness is basically hooked up, trans stuff from Nelson performance worked great and fit perfect. I had to lower the rear of the trans to get the back cooler line on but that was no big deal. Other then a dipstick (cover that soon) it is ready for trans fluid, which i purchased monday. Installed the Kent Moore flywheel tool and tightened the ARP crank bolt until the 24" breaker bar was making a smiley face. Then installed the block ground on the starter side and installed the starter. I have been trimming the harness like crazy, cutting off everything thats not present anymore (like rear 02s, wiper motor, ac stuff, abs plug etc). I ran feed and return fuel lines under the hood and also the hot wires for the pumps. Mounted them on the driver inner fender and they will power off that 12+ stud that's by the fuse block. I got the feed line ran to the rails, which you can see in the pic, there is a y split by the brake booster, and i will dual feel the lines then return them to the FPR. These feed lines will be hidden by the cowl once its re-installed. This weekends goal is to fill with fluids (solve the dipstick issue), test fit the radiator with fans on the front, flip the pins in the connectors so they push instead of pull, finish the fuel lines, and probably run vacuum lines to the wastegate location and in cab for boost control and boost gauge. I'm also a couple fuel fittings short so i ordered those plus an IAC valve which i dont have. I'm one vacuum port plug short for the intake neck so I ordered that also. I may fire on motor this weekend if all this gets done....Turbo kit is one week out.
Quick pic of the fuel pump wiring. All the way to the left is a fuse and relay for the trans cooler fan, that's been there. I add the two fuse holders to the right. I also mounted the fuel pressure regulator and am currently waiting on a couple more fittings and that will be 100% complete.
I went and purchased 16.5 gallons on e85 an put some in the tank so I could flush the lines before i do the final hook up to the rail. I didnt get a chance to test the E content but will. Random pic of trans fluid.
I initially started working on the fan wiring. While reversing polarity on the wires I thought, if the fans are on the front, will this wiring even fit? So I decided to stop, and test fit the radiator, fans, and wiring. Huron speed confirmed this kit will work with the radiator in the stock position, and mid last week i ordered an LT1 radiator cover. On initial fit I could tell clearance to the turbo was gonna be ****, and the stock fans flipped to the front weren't even gonna be close to working, the fan motors were pointed right at the upper radiator support. So i thought im either going to order slimline fans and fab a shroud, or cut the upper support. So I got out the cut off wheels. This is a pic of a previously cut lower support. I cut the entire center section out a year or two ago for weight savings.
Here's a close up of the lower radiator support. You can see its three full sheets of metal in a triangle. The original piece I cut out of the car was like 6 pounds.
So just cut those babies off, or the whole thing if you still have it.
Throw these in the bushes.
Couple pieces of flat bar, 2 90 degree bends later we have brackets. The drivers side has a flat square rubber bushing and the passenger side has a thick round bushing. They are different thicknesses which is why you can see the height difference in the mounts. Also, this mounts the radiator completely straight up and down with no slant, and approx 2 inches lower then stock. The upper support has to be trimmed in from the rear a full 2 inches. Im not sure if Im going to run the factory plastic air dam anymore, have to see once its all together.
There she is in place. After I figure our what Im going to do with the top and I get the radiator exactly where i want it, I believe Im going to go back and add some triangle gussets to the brackets.
Had to tape it because Im not sure what I'm going to do to the top......and I ran out of daylight. As a sidenote there is tons of room for a turbo now......and even, maybe a bigger turbo down the road (insert evil grin). Quickly fit the fans, wow they almost bolt up with no modification.....and the wiring is going to reach.
So we left off with the radiator mounted but taped to hold up top. I originally ordered an LT1 top cover because my plan was to keep the radiator in the stock position, and this was the cheapest route to do that. Now that I moved the radiator I had no game plan. The radiator has moved down almost a full 2 inches so there is no bolt on solution here. I started with trying to fit the fans. The shroud above the drivers side fan must be trimmed some. You also must take off about 1.5 inches across the entire top.
I had to notch and bend just a tad of the upper support for the fans to slide all the way up in position.
Passenger side tab lines up with the condenser mount, driver side i looked for a simple solution since they didn't line up. I folded the condenser bracket down, then just hold the fan in position, drill a hole through the plastic and aluminum, and put a bolt there. You can see it here folded over.
That was pretty easy. I decided to trim down the LT1 top cover and make two short aluminum straps to hold it. Turned out pretty good considering.....The brackets are offset because there were holes already in the plastic so i used them instead of drill more.
Wiring done. It will need to be extended.
E85=E70
Holy mother these pumps move some fuel!!! Went ahead and mocked this up to do a line flush. Good thing i did cause there was crap down in the cups, dont want that getting into my injectors. Quick math fun, stock pump 190 gph, typical Walbro upgrade 255 gph, these are dual 450s, so at 900 gallons per hour its capable of moving 1 gallon every 4 seconds, wowzers! You dont need the key or PCM installed to prime the pumps, pull the fuel pump relay and jump the corner terminals, #30 and #87.
Dialed in pressure to 60psi, and no leaks. I went ahead and hooked up the boost reference line.
So basically everyone b-i-t-c-hes about the Lokar flexible dipstick. My buddy offered a solution (cause there was no way in hell the dipstick and tube was fitting this car), measure stickout, cut the tube, replace with 3/4 hose. So thats what i did. I was able to slide this in and the stick will be hidden under the cowl. I probably wont even make a mount for it.
I also got some of the wiring cleaned up under the hood, hooked up the trans cooler fan, and decided to redo the coolant crossover line. Turbo kit "should" ship monday, I still need a belt and to add the boost gauge inside the cab. We are getting dang close!
E85=E70
Had to tie up some loose ends, needed some coolant line for the radiator connections but got all that handled so I figured I would go ahead and fill up the fluids since it will be starting up soon enough. I plan to run Rotella oil but went ahead and used some pennzoil this time and i plan on doing the first change pretty quick. Grabbed the Rotella when i saw it at the store yesterday, the rest of the bottles are empty.
Removed my trans temp gauge from the middle and replaced it with the boost gauge. I hate two are digital and one is analog but i liked the 65 dollar price tag of this analog gauge. Bottom one is engine temp.
Needed a spot for the trans temp gauge, I had the nitrous panel left over from before so i went ahead and installed it. Its obviously custom made for me, but I may contact the guy and get him to make me a new one with turbo stuff on it, or blank under the switches? Also I got the boost controller mounted where i can reach it.
Jack: 1, oil filter: 0. Whoops, minor miscalculation.....I'm building a turbo car I never said I was any good at it!
Still waiting on this raggedy a s s turbo kit. Starting to get a little irritated. The original estimate was 6-8 weeks and we are now at TWELVE weeks. He says he has the kit in hand but is waiting on a turbo filter and oil lines. I say ship what you got so i can get things fit up and the exhaust made am i right?
Didn't get a ton done this weekend. Had a buddy who needed his 10 bolt rebuilt so I did that for him as a favor. I did get to do a few things, the kit came in late Saturday evening minus intercooler. Randy wrapped the hot-side with fiberglass wrap. I threw some high heat paint on it. Whether it will bake into it, or turn into a smoky mess when it heats up I couldn't tell you. Guess we will find out. I also clocked the turbo where the output faces correctly (forward and down) and drilled and tapped the outlet for the wastegate feed. Huron Speed said just pull the signal from the manifold but that doesn't seem to be recommended so I added one on the turbo outlet. I did a quick mock up, slightly bent the PS lines, and the hotside pipe fit fantastic. Love the extra room standing the radiator up gave me.
I ordered some filters and plan on swapping to the rotella oil after a few heat cycles and before any heavy boost. Also have to replace the coolant tank due to the extra thick hose putting pressure on it and cracking the bottom. I am also going to a lighter duty hose to prevent this error in the future.
Found this guy wandering around. No clue how his wings got so messed up.
Intercooler "should" be here any day and i still need to build the exhaust (likely wrap it as well) and buy a belt. It will be running and driving very soon!
i have done that a few time with the filter actually rebuilding my heads an replace all the gaskets top end ,an had a K&n filter took 2 hours getting it off never had so much trouble getting a filter off brock my filter wrench at the welds, got a 24mm socket on it slowly got it off,going back to wix filters
Intercooler showed up and I had to do a quick mockup just for fun. Brackets fit nice.
The pic above with the turbo mounted.....it was just barely bolted on. Here's why. Not thrilled I had to pull it back off.
Here is my solution. I red locktited them into the flange, time will tell if it holds or not.
Mocked it up on the table to save me some work laying under the car.
Final mount-up, got the alternator mounted up top also.
All the coldside done, it lacks a belt at this point to be running.
Got the tubular bumper support to work with the intercooler....it required some minor trimming.
They said 73 inch belt, that turned out to be too long. Ive got a 71 on there now but its a smidge too tight but will work for the moment. The stock tensioner gets relocated to where the alternator used to be, and the iron blocks dont have one of the holes for the mount. I ended up grabbing the side bolt hole and making a bracket from scratch, and so far its holding good.
You can see the bumper was already cut for airflow to the trans cooler, but i wanted to trim it more. This is what I started with.
This is how it ended up.
What do you do when you want your exhaust tip centered but dont have anyone to help you?? Well you electrical tape bolts to the dang thing. Made great spacers.
Turned out nice I think. I did go back and paint the hanger/frame red.
Piece to the front brake line. I found it crushed and replaced it. No clue how that happened but glad i saw it.
Ive got the segment swap done, and the 3bar VE with real time tuning, which Ive been playing with and its cool as ****. It was fighting me all day but i believe I had incorrectly input some of the injector data. I was starting to make some progress but ran out of daylight. It also added some fuel to the oil (running pig rich) so I got that crap out of there and put the Rotella in. Motor purrs and is very smooth but now Im showing no oil PSI, Im thinking my chinese sending unit didnt like the e85 oil. But, no leaks, and Ive heat cycled it about 5 times. Fuel psi crept down to 50 psi? So i dialed it back up to 60. Little crap now at this point.
