t tops!!!!
Old Jan 4, 2008 | 09:50 PM
Rs Camaro Kid's Avatar
Default t tops!!!!
im lookin at a 94 z28...i have it for the night and the rest of the day tomarrow, ive been told form a friend that works at the dealer that the t tops leak...he didnt say how much
is there a way to tighten down the tops instead of buying new seals for them???
Old Jan 4, 2008 | 10:04 PM
drumr2790's Avatar
Default RE: t tops!!!!
How many miles does it have? Mine don't leak, but a window does (but that's because it's off track). I don't think there's a way to tighten them down tighter (they're already pretty tight). If you do buy it and intend on driving it in the rain it'd be best just to get new seals.
Old Jan 4, 2008 | 10:11 PM
there are 105 k on the car...and seals are pretty expensive
Old Jan 4, 2008 | 10:47 PM
any other suggestions?
Old Jan 4, 2008 | 10:55 PM
drumr2790's Avatar
There's some soft, black, spongy tape that I can't think of the name of that might work. You could try tearing some seals off of a vehicle, cut them up and glue them where the t-tops leak. Other than that I can't think of anything else.
Old Jan 5, 2008 | 01:15 AM
The pins on the t-tops drive into receivers front and back, and they are adjustable. You need to carefully remove the windshield pillar trim panelsand the rear trim panels to access the mounting bolts.
Old Jan 5, 2008 | 08:23 AM
alright thx
Old Jan 5, 2008 | 12:27 PM
cbr600rx7's Avatar
You can pick up a seal kit for aroun 220 bucks. Thats t-tops and trunk.
Old Jan 5, 2008 | 02:22 PM
qmracer's Avatar
Why don't you spray the thing with a hose to find out where and how much they leak. I know that mine are fine with rain and direct pressure from a hose but automatic touchless carwashes get right in(only the high pressure rinse not the soap). When water gets in my car it is actually the seal around the window and at the back edge of wherre the t-top seals meet the seal for the window, they may just not be seated right though
Adam78
Nov 21, 2009 09:46 AM
Camaro SSuperman
Sep 15, 2009 04:41 PM
97Z28
Aug 26, 2008 12:34 PM
79projectZ28
Oct 22, 2007 05:50 PM
95greenbean
Aug 9, 2007 09:09 AM
