t-top switch
Old Apr 29, 2011 | 09:56 AM
rusch69's Avatar
Default t-top switch
i got a 1993 z28 that unfortunatly does not have t tops. my buddy has a 2000 camaro with t tops but the car is wrecked. ive looked at both of them and it looks like the roof should just come off but i was wondering if anybody has done something like this or if it can even be done
Old Apr 29, 2011 | 10:18 AM
it can be done, havent seen anyone on here do it yet though.
Old Apr 29, 2011 | 10:30 AM
BasicConcepts's Avatar
Technical User
just cut the 2 roofs off with a sawzall and weld the ttops to your car
Old Apr 29, 2011 | 10:57 AM
it shouldnt be much different than adding aftermarket t tops. thing is they almost always leak.
Old Apr 29, 2011 | 12:13 PM
The t-top provisions are already there to make it work on your car, you just gotta do a little cutting and digging: Grip's T-top Conversion
Old Apr 29, 2011 | 04:52 PM
Grandpaswagon's Avatar
If not done correctly, you can be assured that they will leak. Even factory T-Tops leaks if the seals are not just right.
Old May 24, 2011 | 07:31 PM
androzer's Avatar
watch youtube, i have seen many
but as my advice , it will leak!!!!!!!!
Old May 24, 2011 | 10:44 PM
H2C's Avatar
H2C
mine leak if i dont latch them right, so if you do this it will have a 99 percent chance 0f leakege.
Old May 24, 2011 | 11:08 PM
Phalen123's Avatar
arent the ttops released by a key though?
would you have to get the key from the old car to use them?
Old May 25, 2011 | 12:27 AM
Technical User
they can lock with a key theres actually a handle that releases them as long as there not locked your good
