sway bar noise!
So i have an 02 SS, and i put a set of Spohn swaybars on it about a month ago. The instructions said to put the supplied grease on the bushings. I did that, but now its squeaking bad now and is coming from where the bar is mounte on the chassis in the front, and where the rear bar is mounted to the rearend. Is this normal? Is there anything i can do quiet it a little bit?
