Stripped intake thread
#21
11/32 drill bit is what you use if you are tapping for a 3/8-16 hole. However, most heli-coil kits work by drilling and tapping to the next biggest size. The heli-coil will have that bigger size thread on its outside and the smaller thread you need on the inside. Those are how the heli-coils we use at the plant work..not sure if they are all like that.
#22
This type heilcoil has the same pitch as the thread being repaired meaning you need special heilcoil tap with a larger diameter but the same pitch. That is why the tap comes with the inserts. That tap will define the drill size. The numbers I posted are from the heilcoil manual.
There are much heavier thread repair insert. This is a common insert used in industrial applications.
3/8-16 Inch Internal Size, 9/16-12 inch 36753580 - MSC
#24
uh oh dont leave us for hollywood now crabby lol
Please dont make me panic guys. I have the 95 LT1 and the bolt size is 3/8. I ordered a helicoil kit from amazon yesterday. Drilling a bigger hole was what i originally thought i had to do to get the OEM size bolt in, which i hope is not the case since i dont feel to comfortable doing that. Below is the link to the exact kit i bought.
https://www.amazon.com/Helicoil-5521...%2F8++HELICOIL
#25
You need to drill out the hole with a 25/64" drill bit, then tap the hole, then install the insert. Don't forget to use oil when tapping. Take a deep breath, go slow, and you'll be fine.
#26
rs657f
Do you have access to a drill press? If you can make a tap block it would make the process less touchy.
Tons of videos on youtube
#27
I wish I had a drill press and a garage at least lol thats my next goal. I received my helicoil kit in the mail. It definitely isnt the one in the link but it will work. I see the tap is way bigger to create the 3/8 thread. Ill go get the bit and give it a shot this weekend.
Thanks for all the help again guys
#28
The better Heli-Coil® kits come with drill bits
R1185-6 includes X drill bit, $26 at Grainger
https://www.grainger.com/product/HEL...Query=r-1185-6
DON'T FORGET to break off the install tab at the bottom of coil after installing.
