Stereo help!
My project 93 is definitely a puzzle. Sorry for the pic quality. I just used my crappy phone instead of getting my camera. Here is what I know, most of the lower dash including the radio area was all taken a part when I got the car. The car is a 2000ish SS clone. The radio I found in a box is a Monsoon. It has a manufacture year of 2000.
What looks like a factory wiring harness is still there and when I plug the Stereo in it sounds pretty good. Better then my 96 which still has the stock speakers. I pulled the cover of and it look like a white Sony 3-way round speaker.
Connectors
Sony
In addition to all the stock wires I have these?
Connector like a home stereo?
2 sets of speaker wire?
I have no idea what these are for?
I also have these in the back
I noticed the Stereo has a Aux next to CD, Is there a way to make this work with an Ipod or my Phone?
Connectors
Sony
Is this what I need to add a MP3 player to my Monsoon system? Is there a cheaper one out there? I do not need Aux1 and Aux2.
Chevrolet Auxiliary Audio Input Add Aux MP3 Player iPod etc to Factory Radio | eBay
Edit, found this also
http://www.ebay.com/itm/PAC-Audio-Un...80317d&vxp=mtr
Pac Audio Universal Dual Auxiliary Input iPod iPhone MP3 GMC Chevrolet aai GM12 | eBay
The only cheaper way to go involves some "surgery" to the head unit to tap into the internal CD player/tape lines. Even then, the internal CD or tape player must be "playing" something for these inputs to work. I did this for my 98 Monsoon head unit. It's a bit of work.
Thank Gary, I am not sure I want to go as far as cutting into the internal harness. If I understand you right, if I buy the above adapter I just need to be sure I have my phone/Ipod plugged in and running before I hit the AUX button.
I do not have a remote CD. The radio has the plug for it.
No that's not it. For either of those adapters to work, you have to have the remote cd player, and it has to be playing a cd. The adapter lets you switch sound from the cd that's playing to whatever you have plugged into the adapter's cables. That's do-able because the audio signals travel though the 9-wire cable between the head unit and the remote unit. The head unit communicates though a single wire in that cable. If the remote cd player stops for any reason it "tells" the head unit it has stopped and the head unit switches off the connection, and you can't hear the MP3 device.
With the internal mod, even then I have to be playing a cd in the head unit and I hear the MP3 player instead if it's plugged into the jack. When I unplug the MP3 player, then the cd that's playing can be heard. A switch could have been used there too, but i didn't think I would be switching back and forth much. I only did it this way because I want to keep the car completely original (or close to it).
These head units aren't easy to hack because all the switching between modes take place inside the chips on the circuit boards. This is why most folks just buy a new head unit with an AUX jack and/or USB socket already.
edit: I kept typing 12-pin when I mean to type 9-pin or 9-wire.
By the way, the first link is for a PXGM9 adapter, which is no longer made and is exactly the same as a currently-made AAI-GM9 adapter. Both are for radios with the 9-pin connector. The second link is for an AAI-GM12 which is for a later year radio with a 12-pin connector.
I would probably go with one that at least has a USB socket. You can put all your MP3 music on the USB device and the head unit can display the titles, album name, performer, etc... to help you select it. The phone/iPod/Mp3 jacks just allow you to play the music, and you have to use the device to select it. And the USB device can be a tiny one that is barely visible.
My son said that too, he's the stereo guy at my house.I went after market on my stereo to get the usb.
