Steering Replacement
If I remember right the hose are more of a bear then the rack itself. 30 year old rack, Those outer seals may not have much longer. Also if the pump fails and sends metal through the rack that can cause issues. With all that room I would be tempted to add a filter to the high pressure side while it is all a part.
Where did you put the cooler at? 4 gens are not known for their spacious engine compartment.
