Starting problems.
Old 02-16-2011 | 08:24 PM
chrisgray86's Avatar
Default Starting problems.
Ok guys so that radiator leak that I asked a question about last time it was the upper and lower intake gaskets that were leaking. So while the shop was in there they saw that the fuel injector gaskets were leaking so they replaced those. I got the car back today. And its having another issue that I know they caused. When you turn the key in the ignition to start the car it tires to turn over, completely stops and makes no noise then about 2-3 seconds later it cranks up no problem this is all with one turn of the key. Any Ideas on what they jacked up?
EasternStryker
02-28-2010 10:57 AM
videojunkie1986
06-03-2009 07:02 PM
justingarcia947
10-08-2008 01:25 AM
KrazyHobo
11-20-2007 08:48 PM
jdubs1813
11-08-2007 02:42 PM
Quick Reply: Starting problems.
