Starting Problems
hello i am currently having problems with my 97 camaro 3.8 the problem is when i try to start it sometimes it start and some times it will not so i think i have a short some where.I have also heard camaros have bad ignition switches so i don't know if that could be the problem also on my key where the black electronic piece is it's not tight it is very loose and i was wondering if that could be the problem. This is my first car so help would be appreciated thanks !
is it turning over and not starting or it wont turn over at all. no clicking or nothing? u will need to find the ohms on the key pod. call a couple parts stores and dealers to see if they have a key reader and how much it would be to find out what key u will need. if its your vats that is acting up then that could be it. are u getting a security light? if u have a ohm meter u can check the ohms your self. check this out and see if it helps.
http://shbox.com/1/4th_gen_tech2.html#pass_key
Thanks yes if you hold the key in the start position it makes a clicking noise and the dial on the speedometer would go up i think the reason the clicking is because i have a dead battery, obviously because i have a short which may be draining the battery. But i am going to get a new key but i have to get it running good enough to get tags and get it registered to get a key made
clean the the battery terminals and the battery cable ends. wire brush the heck outa them. then clean the wire ends in your power juntion box. red plastic box on the passenger side wheelwell by the battery. take the nut off and wire brush the wire ends then hit the box nut with some electrical cleaner. u may want to put some electrical grease on the connections to help stop/slow corrosion if u have any. stuffs not cheap.
ok, thanks i will try that if that does not help after i get it registered i am going to take it to a local shop to get a check over every thing. By the way do you know any improvements to do to a 3.8, easy to do i have been looking at cold air intakes and a cat back system but it hard to find each for a 3.8 do you know any good sites or products thanks.
