squealing pullies
Old Oct 3, 2012 | 03:34 PM
Big Zeus08's Avatar
Default squealing pullies
when i run my engine the pulleys make a squealing noise. so i know this is a common thing with chevy v8s cause it happened on my dads suburban. but now its happening on my 2000 camaro ss and its really bothering me does anyone know of anything i can do to lubricate the pulley so it doesnt squeal anymore while the engine runs
Old Oct 3, 2012 | 07:34 PM
Failed Devices's Avatar
Which belt is squealing? Do you need a new one? It could be old, worn, cracked and stretched out which would make it squeal.
Old Oct 3, 2012 | 08:43 PM
I doubt very much that the pulleys are squealing, most likely the belt is slipping. Lubricating the pulleys or the belt is not going to work for long. Find out if any of the accessories are binding, and causing the belt to slip, make sure the belt is not glazed or damaged, and make the sure the tensioner is up to spec.
Old Oct 3, 2012 | 09:37 PM
BasicConcepts's Avatar
Technical User
belt lube (belt dressing) is a really bad thing to use on serpentine belts it will cause the belt to slide off the smooth pulleys. like pete says im sure its not the pulleys themselves but the belt either too loose or just plain worn out, replace the belts and go from there. also get good quality belts like gaterback, in my experience there the best.
Old Oct 4, 2012 | 10:20 AM
Big Zeus08's Avatar
Okay thanks guys, I just bought the car a month ago so im not sure how old the belt is but you are all probably right that I should replace the belt
Old Oct 4, 2012 | 11:32 AM
Big Zeus08's Avatar
do you know what length belt i need
Old Oct 4, 2012 | 03:29 PM
Technical User
just go to the parts store tell them you need a serpentine belt and an ac belt.
Dana
Sep 23, 2013 11:37 AM
Viridian1991
May 28, 2011 12:52 PM
dhill
Sep 23, 2008 08:16 PM
350rs
Dec 31, 2006 01:28 PM
shnormo
Nov 9, 2006 10:03 AM
