Speed Limitor..
Old 07-23-2007 | 09:19 PM
tyler2497's Avatar
Default RE: Speed Limitor..
if u get the speed limiter removed on a 115 speedo then go like 150 will it break it
Old 07-24-2007 | 07:25 AM
RS.Camaro.SS's Avatar
ORIGINAL: tyler2497
I personally have never heard of people having a problem with going past the numbers, but im sure if u did it quite often it would have some negative effect
Old 07-24-2007 | 08:03 AM
#12's Avatar
ORIGINAL: 95slvrZ28
ORIGINAL: red star
ORIGINAL: 95slvrZ28
I'm not sure about the sixxers, but I know that the Z28's came speed governed at 108 mph if they were not ordered from the factory with Z rated tires. I'm not sure if Z rated was even an option for the sixxers, so I'm assuming that they're governed as well. If you want to take it off you'll have to get the PCM reprogrammed, either professionlly or you can utilize the Hypertech power programmer, but it's kinda pricey.
108? are you sure? mine hits 140...
Sounds like the limiter has been removed. The reason for the 108 limit was due to the fact that it is slightly under the speed rating for S rated tires(rated for 112mph), so if your car can hit 140 the PCM has already been reflashed.
i have a 2000Z and i bought it new and i have never had any speed restrictons, nor have ihad it flashed or reprogramed. i have got her up to about 130, with no problems. so.............................
Old 07-24-2007 | 11:52 PM
95slvrZ28's Avatar
ORIGINAL: #12
ORIGINAL: 95slvrZ28
ORIGINAL: red star
ORIGINAL: 95slvrZ28
once again, it was probably ordered from the factory with Z rated tires...
Old 07-25-2007 | 08:04 AM
1994greenchevy's Avatar
well mine can hit 120, and that means the cop before me had some serious fun with this car. lol
Old 07-27-2007 | 03:00 PM
M.$tErNeR's Avatar
i wonder if mine does.i have a 98 z28 so would that 108 apply to me too? or was the speed limitor higher on a ls1? if not is there anyway to find out without actually trying to max it out?
Old 07-28-2007 | 01:45 AM
95slvrZ28's Avatar
Look at your speedo, if it has a 150 mph speedo, you're not limited. If it has 115, it was limited from the factory.
DiElSleL
03-08-2012 01:23 PM
DiElSleL
03-06-2012 10:54 PM
rext
67-69 V8 Tech
09-23-2011 11:49 AM
Quick Reply: Speed Limitor..
