Sparking noise?
Old Jan 28, 2011 | 06:42 PM
sebi1990's Avatar
Default Sparking noise?
Hi guys, im hearing this sparking noise:
http://www.youtube.com/watch?feature...&v=kVNyyV-rv58
and its coming from around this area:
what might it be?
Old Jan 28, 2011 | 07:37 PM
osduck5's Avatar
May just be my laptop speakers, but that don't sound like a spark as much as it sounds like a ticking. More like a lifter tick. If you are sure it is a sparking noise, look to see if you can see any plug wires arching.
Old Jan 28, 2011 | 09:52 PM
yah stick your hand down there and see if it shocks ya. start er up and turn the lights off and check for light show. i cant hear anything sparking. could be a lose spark plug or exhaust leak but most likely what duck said.
Old Jan 29, 2011 | 02:02 AM
Massey's Avatar
try unplugging the EVAP purge valve and see if it goes away. I cant hear what you are talking about here at work so I am guessing on what it could be. I have heard mine cycle a few times and I could not believe how loud it was. The purge valve is the black thing with the hose and 2 wires in the place you circled. Just unplug the 2 wires. Also doing this may throw a code, no biggy, it may clear once it is plugged back in or just go to the AP store and clear it. I will listen to the vid when I get home from work tomorrow.
Massey
Old Jan 29, 2011 | 02:20 AM
sebi1990's Avatar
Thx guys massey ill try it and let u know
Old Jan 29, 2011 | 08:10 AM
osduck5's Avatar
I think Massey is pointing you to the noise unless you are hearing something other than the purge valve. I started my daughters 98 and I hear the same noise coming from that valve sounding just like what I hear when I play your vid.
Old Jan 29, 2011 | 11:59 AM
sebi1990's Avatar
so duck did u figure it out what might be causing the sound? I'll try masseys idea today
Old Jan 29, 2011 | 12:00 PM
sebi1990's Avatar
Massey
and you might be right because that the seems like the main source of the sound
Old Jan 29, 2011 | 12:33 PM
Massey's Avatar
If it is the source of the sound dont worry about it too much. Unless you get a code for a bad purge valve I would not worry about it.
Massey
Old Jan 29, 2011 | 01:54 PM
sebi1990's Avatar
Yeah but the thing is that the ticking noise i can hear from the inside of the car and every time i speed up it gets louder hehe
