Spark Plug Question
Old May 16, 2009 | 04:17 PM
sbono's Avatar
Default Spark Plug Question
Hey there, I have a 94 Z28 LT1 w/6m. My question is how do you remove #8 spark plug? On top of the you have all the air conditioning hardware and the dipstick in the way and under the car you have the y-pipe and the stater in the way so you can't even get your hands in ther from under the car. Any tricks or special tools required?
Thanks.
Old May 16, 2009 | 06:54 PM
need someone with skinny arms. i scraped my arm up getting to mine. easier with a long handle flex rachet. can take starter lose and move it, unhook the battery. use really good plug so u dont have to do it again for a long time.
Old May 16, 2009 | 10:32 PM
Y2K's Avatar
Y2K
I had new wires and plugs done on mine at a friends shop Friday,I didn't have the time or place let alone tools or lift to do it myself so I coughed up the money and had it done.
I watched while they did it,what a PITA even with the right tools and a lift.
They dropped the cat and y-pipe to get at it,air tools and being able to walk under the car made that a lot easier but even with the exhaust out of the way changing the wires wasn't easy.
Old May 16, 2009 | 10:41 PM
yah aint life grand. i did my wires when i did the opti and oil pan gasket. was not fun but with the exhaust and starter out of the way and the engine lifted up was not bad at all.
Old May 16, 2009 | 11:21 PM
greenarrow's Avatar
September 2009 ROTM
What craby said, that's how I've always gotten mine.
Old May 17, 2009 | 01:12 AM
Y2K's Avatar
Y2K
Sometimes I sure miss my '69,even with a 427 big block and big tube headers all I needed to change all 8 plugs and or wires was a ratchet a socket and 15 minutes under the hood.
Old May 17, 2009 | 10:05 AM
sbono's Avatar
Yeah, I hear you Craby, my hands and forearms are chewed up pretty good. All I have is basic tools and jack stands. It took me four hours to change seven plugs. I will be replacing the plugs with AC OE plats and using a 8mm Taylor wire set. How much of a pain will it be to route those? The reason i'm doing this is because I lost my water pump last moday while going down the highway. Since I got everythng out I might as well change plugs, wires and opti. I ordered a GMPP opti from summit racing, just waiting for it to arrive. Thanks for the replies guys.
Old May 17, 2009 | 10:31 AM
drivers side wires are easy. passenger side is not. having the pump and opti out will make it as easy as its going to get.
Old May 18, 2009 | 02:02 AM
torque_is_good's Avatar
just think, for what you paid someone to do the job for you, you coiuld have gotten long tube headers. I can't believe how easy it now is to get to the plugs compared to before. Of course, getting the headers in is another story but the pain numbs with time.
Old May 18, 2009 | 03:26 AM
SSV6's Avatar
lucky you, I've gotta all but drop the motor out of mine to get a the plugs.
