spark plug look if head gasket bad
Coolant loss does not lead only to "blown head gasket". If that's your only symptom, I would look else where. Start checking for leaks instead. Lower intake gasket, rad hose, water pump gasket or weeping hole, heater core(wet carpet) heater core connections. Etc
Yeah I know it's the hard way but we're at the house bored and autozone is a nice drive from me.
Is this what you're talking about OEM/Radiator and cap test kit (27065) | Cooling System Test Kit | AutoZone.com_
I know last year when it evidently was the rad cap, I didn't have anything on the carport but what about the other things?
I'm sure its in lighting. If something is wrong with one then it is with them all. They look identical.
We didn't put these in so can't tell u anything about them. I just know the spark plug puller fit them and was too small on one of our other cars. So if I go to parts store and tell them I need them for specific car will they fit? I know it's not original motor but looks same as the other 95 motor.
#20
Those plugs are way too dirty to be a blown headgasket, the first plug looks like your leaking a little oil into the combustion chamber. When you go to the parts store just tell them you have a 95 3.4 and get regular AC copper plugs.
