Some transmission/shifting questions.
Old 07-02-2007 | 11:01 PM
Conundrum's Avatar
Default Some transmission/shifting questions.
I've had my WS6 for around two weeks now and I feel like I'm getting used to a standard transmission rather well, it's my first ever. I've been playing around with it and I've found that at times I don't even need to use 2nd and 3rd gear. However, I've noticed that when I go straight from first to third it will sort ofhop just a bit, also the same when going straight from third to fifth. I'm doing this mainly to try to squeeze as much gas mileage as I can out of the car but at the same time I don't want to hurt the transmission or clutch. Just curious if it's ok to skip gears like that and if that slight hop is normal. I've also tried shifting normally at lower RPM's but I also get that same hop I described earlier unless I rev slightly higher. Any other gas saving tips will be greatly appreciated.
Old 07-11-2007 | 06:53 PM
1994z28's Avatar
Default RE: Some transmission/shifting questions.
ITs called engine lugging. when you shift from 1st to 3rd you are bogging the engine down andit takes the engine a few seconds to get the transmission up to speed. i dont think it causes damage to any parts, just causes a crappy ride.
Old 07-11-2007 | 07:17 PM
SpecterGT260's Avatar
Ninja Administrator
i usually drive 1-2-4-6 and skip 3rd and 5th. 1 is such a short gear that the car will tend to lurch some when you shift out of it. the 2/4 shift is smoother at least imo
Old 07-11-2007 | 11:13 PM
BAN WS6's Avatar
Conundrum under my new name:
Thanks, I've been getting used to the feel of the car and it's smoothed out for the most part. I'm getting around town fine, now I plan on taking it out to somecurvy countryroads and trying to get the feel of a more racing/sport type of driving. I appreciate the advice.
kronick
70-81 V8 Tech
08-10-2009 05:10 PM
tripwire1124
06-24-2009 09:06 AM
GRIFF
70-81 Transmission & Differential
06-07-2007 08:36 PM
psycledad
09-14-2006 07:10 PM
trash
82-92 V8 Tech
01-06-2006 11:48 PM
Quick Reply: Some transmission/shifting questions.
