Slid into curb.. Scary! With pics
It is where they check the front and rear suspension and align all 4 corners of the car together. It gives a much more accurate alignment and it can also detect defects in the rear suspension which can effect tracking and front alignment (such as bent lower arms or panhard arm). Anytime you modify the rear suspension or get in a hit like you did it is highly recommended you get the 4 way thrust alignment.
Massey
Massey
Nickplee - when you get the new rims on get some one to follow you and make sure your wheel isn't wobbling, i clipped a curb once and it bend my axle shaft ever so slightly, car was fine and could feel it but my wheel moved by like an inch so had to replace the shaft
^ auto, that could be due to the caster setting on the front, if one is a little bit out the car will track badly. Mine used to do this so i got the caster set equal
The crown of the road will also cause the car to pull at times. This is normal and there is nothing you can do about it.
I agree with Maudy about some one following you. Not only to check for wobble but to see if your car dog tracks down the road. If it dog tracks then you know your panhard bar is bent.
Massey
Massey
Massey
Massey
Dog tracks? is that where the rearend isn't exactly behind the front end?
Massey
