skip-shift wont let me down shift
Old Sep 28, 2010 | 08:27 PM
bigtim1985's Avatar
Question skip-shift wont let me down shift
i recently bough a 2001 trans am ws6 6speed. it is completely stock. stock shifter no skipshift eliminator. the trans shifts great except downshifting from 3rd to 2nd. it wont let me shift into 2nd. and its not the syncro because its not grinding at all....it feels like the skip-shift is activated and wont let me downshift. even double clutching or rev matching makes no difference. but i would say 3 out of 10 times i can downshift from 3-2. any thoughts? is it possible to take the solenoid out with the trans in the car so i can test it? maybe the solenoid isnt fully retracting. there doesnt seem like there is much room to get it out though. thanks- tim
Old Sep 28, 2010 | 08:52 PM
Failed Devices's Avatar
How fast are you going when you try to downshift? You could try doing the skip shift eliminator (even though it is mainly used for the 1-4 skip shift, it still might help with the solenoid). I know in my Trans Am, I can't downshift into 1st gear when going like 15 mph or faster.
Old Sep 28, 2010 | 10:01 PM
bigtim1985's Avatar
the 2-1 downshift is fine just the 3-2 downshift
Old Sep 29, 2010 | 01:18 PM
bigtim1985's Avatar
anybody?
Old Sep 29, 2010 | 03:54 PM
Raingler's Avatar
I don't think it's the skip-shift, least mine didn't do that, BUT, no way I'd ever go back to having it operational either!
Old Sep 29, 2010 | 07:23 PM
A bad sync will cause this and not grind. Grinding is normally caused by the clutch not fully disengaging. A bad sync will cause it to be hard to shift.
Old Sep 29, 2010 | 11:28 PM
bigtim1985's Avatar
ok so most likely the 3-2 syncro is bad.....kinda what i was figuring but hoping it was something more simple. rebuilding the trans should be a fun winter project.
family man
Mar 29, 2011 09:06 PM
sbono
Apr 12, 2009 11:28 PM
nazariol
Sep 18, 2008 06:30 PM
kender
Oct 1, 2006 11:18 AM
o2camaross
LS Series Tech
Aug 26, 2006 02:23 AM
