single piece driveshaft
Old 06-17-2012, 06:47 PM
heinrocket's Avatar
Default Single piece vs two piece driveshaft
As far as strength is concerned they are both good.
Old 06-17-2012, 08:04 PM
v64thgen's Avatar
Originally Posted by heinrocket
My experience is that the two piece has less vibration at high rpm and the single piec has less vibration at low rpm. Overall i like the single piece
do you notice any more responsive/smooth accel/decel?
Old 06-18-2012, 05:30 AM
heinrocket's Avatar
Default single piece prop
Mostly just the smoother engine vibration through the low to mid range rpm
Old 06-26-2012, 08:06 PM
v64thgen's Avatar
I have been lookng into this mod, and on some other forums some guys say they have had some issues with breaking transmission mounts when switching fro the 2 piece to a 1 piece. They talked about relocating the torque arm bracket to fix the problem.
Is this only a problem if there is more than stock power (+50-100 hp) and/or a heavy right foot?
any thoughts?
Old 06-26-2012, 09:59 PM
I can't see what difference the driveshaft would make. It's the lifting force of the torque arm that wants to tear at the mount.
The Z28 only had a one piece shaft, and it's gonna eat a mount easier than the V6 will.
Curt705900
05-07-2012 05:15 PM
richard.nelson100
12-26-2011 07:22 AM
gville4life
10-25-2010 09:25 PM
Quick Reply: single piece driveshaft
