shifter question??
I don't have experience with this first hand but a buddy of mine had the bolts strip on the shifter mount and the actual shifter became dislodged. He could still shift fine but he kinda had to hold it up himself to keep the stick from dropping down. Its possible its an easy fix.
40 or 50 bucks for parts and an hour or 2 of time. Not easy and not too hard. Gotta get the car in the air by jackstands or other means. Then have to jack the trans close to the tail section. Unbolt the three bolts held at the cross member and trans and swap it out with the new one.
Take your time and do it safely. Mine came with a broken one when I traded last year.
thanks guys!
it does thump under the car when i take off or shift fast. sounds like it is the tranny mount. will go to the parts store this weekend.
any ideas on a site to order cheap performance parts?
and a good place to start for mods? The car is completly stock it has the 3" stainless steel exhuast already from factory and sounds about where i want it too, so...
