shift improvement module
Old 10-20-2008 | 11:28 PM
doww301's Avatar
Default shift improvement module
Has anyone installed one of those "shift improvement modules" sold by SLP? If so, how well did it work - notice any improvement in shift firmness, or is buying and installing this just a waste of time?
thanks![8D]
Old 10-21-2008 | 12:53 AM
Nessy's Avatar
Default RE: shift improvement module
You mean like a shift kit? Their not to expensive and not a bad investment if you are going to get a good one and get it properly installed (install can be a pain.) Remember, the l460e is actually a really good auto transmission (especially compared to mustangs) and shifts well when you need it to. You'll notice it slam into gears harder, but make sure you don't go with a cheap one thats going to make your trans really vulnerable to internal wear. Most people don't waste their time installing a small stall, so you might as well aim pretty big if you do go through with this.
You really want to get that auto running though, go ahead and throw a torque convertor in their as well.
Old 10-21-2008 | 10:24 AM
doww301's Avatar
no, i'm familiar with the B&M kit where you drop the pan and the valve body, this is some type of electrical box you splice into your wiring- don't know if it does something to increase pressure within the tranny-here is the link to the page that it's listed on -http://www.slponline.com/browse_list.asp
thanks
Old 10-21-2008 | 10:27 AM
02StanGT's Avatar
What year is your car? I used to have one, and you could tell it shifted harder. Now I have tuned my computer to do the same thing as that.
doww301's Avatar
ok - well, sorry the link didnt go where I thought it would - if you go to "slp online" and click on 93-97 F body - then go to section "PCM and Electronic" you will see it at the bottom of the page.
Old 10-21-2008 | 10:28 AM
doww301's Avatar
I have a '95 Z.
Old 10-21-2008 | 10:31 AM
02StanGT's Avatar
If you everplan to get the PCM tuned, you can have them do that as well, and save your money w/that module. Unless you like the idea of flipping back to stock just like that. Not sure if you are at the point of needing or wanting the PCM tuned though.
Old 10-21-2008 | 01:57 PM
I used to have a 96 Z, and had a power programmer for it. Shift firmness was one of the features, and it changed it by altering the PCM. Looks like the SLP module does pretty much the same thing, just with an in-line module to alter the signal. As far as the results, yes it is noticeable and worthwhile. The nice thing, is you can put it back to "normal" when you go to sell the car. (that way the buyer won't know you were beating on the car)
B_rad23
02-04-2011 07:28 AM
Camero Cowboy
11-17-2009 06:16 AM
RS96LSU
VS
09-30-2009 12:27 PM
Z28 Kid
04-12-2008 12:01 PM
iriswalsh04
04-19-2005 09:21 AM
Quick Reply: shift improvement module
