She won't downshift
I have the auto trans in my 94 z28, its always worked fine, But I was driving her yesterday and When I came to an intersection and itwas still in third gear.. Its a dawg when I take off in third, I manually put it in 2nd and it went into second then I put it back into drive and it stayed in third no overdrive?? I don't really know where to start. If the car is cold I and start it and put it in drive it will start off in 1st gear again. Then After it shifts into second It will not go back into 1st.. I think I'm going to get the trans flushed then change the fuild and filter maybe the valvle is sticking or sumthing I need help, I still have some time left this year to beat on my camaro.. THank you
just take the beast in. everyone thinks tranny's are a big deal but in ohio you can buy a junk yard one with warrenty for like 3-400 (not to bad) i acctually just swap trannys when something breaks. easier then messing around with the inside of it.
