SES 0174/0171 help
Old Feb 17, 2011 | 09:36 PM
auto's Avatar
Default SES 0174/0171 help
0174- fuel trim bank two condition
0171- fuel trim bank one condition
first time i got a SES light, does this sound like the fuel pressure regulator or the fuel pump?
Old Feb 17, 2011 | 09:44 PM
Massey's Avatar
I pick up system too lean bank 1 and 2. Common causes are FPR stuck open, clogged fuel filter, low fuel pressure, bad or incorrect MAF/MAP reading.
Massey
Old Feb 17, 2011 | 10:04 PM
auto's Avatar
time to go under the hood! plugs came today, is it safe to spray maf cleaner in the maf?
Old Feb 17, 2011 | 10:10 PM
Massey's Avatar
Yea it is safe to use MAF cleaner on the MAF sensor. I would take it off the engine first, if you can.
Massey
Old Feb 18, 2011 | 10:06 AM
Check this link for additional info & test procedures.
http://www.gearchatter.com/viewtopic11742.php
Old Feb 18, 2011 | 03:16 PM
auto's Avatar
okay results-
changed the pcv valve, and noticed the two inch hose between the pcv and intake cracked and had a hole in it, the fat end of the old pcv had some oil on it. looked at other hoses didnt notice cracks.
put 4 new plugs on the driver side with msd wires, car seems peppyer but the rear wheels i can feel a hop/skip when burning out or taking a turn on the gas. maybe i`ll just go back to a basic rubber mount, thats whats causing it though? right?
Old Feb 19, 2011 | 09:25 AM
auto's Avatar
would the light come off by itself if the problem is fixed or would i have to clear it with a scan tool?
Old Feb 19, 2011 | 09:59 AM
Massey's Avatar
It will eventually shut off by itself but it could take a while depending on driving times and habbits. It is best to turn the light off with a scan tool and if it stays off your problem is solved if it comes back on then you know you didnt fix it.
Massey
Old Feb 19, 2011 | 10:08 AM
auto's Avatar
thank you massey, i`ll just clear it with a friends tool, im not driving around alot since its been dumping gas
Old Feb 19, 2011 | 03:20 PM
auto's Avatar
update- i gunned her *ss on a straight, and when it was throttling down SES went away and didnt come back, still going to change the rest of the plugs.
