Security system
I recently baught a 99 v6 3.8L and I think the previous owner had a aftermarket security system installed because he lived in Atlanta. Every time I turn the car off and shut my door the horn honks twice after 5 seconds. Also the alarm starts going off after doing the simplest of things like opening my door if it’s unlocked and the car is off or trying to open the trunk after I’ve turned the car off. Things like that. Any advice on how to remove this or disable it would be appreciated |
Originally Posted by Forest Williams
(Post 729581)
(Post 729581)
Also the alarm starts going off after doing the simplest of things like opening my door if it’s unlocked and the car is off or trying to open the trunk after I’ve turned the car off. Things like that. Are you unlocking the car by using the key or are you using the key fob? If you have a factory security system, I believe the fob is used to activate and deactivate the alarm. Again, the owners manual will describe how the alarm works. If you don't have a copy, let me know and I will post a pdf of the section that pertains to the alarm system. |
