Replacing rotors.
Old 02-18-2008 | 01:15 AM
Default RE: Replacing rotors.
If you go back and re-read Ban's post again, you'll notice he didn't replace his rotors. And since he said he couldn't get them off, he obviously didn't get them dressed down either...doing neitherisa big no-no! The scraping he is hearing is probably from the crusty build up of rust on the inner and outer edge of the rotor that the new pads are now riding on. By the way, warped rotors won't cause a scraping sound, it will cause a pulsing sensation in the brake pedal.
Old 02-21-2008 | 08:31 PM
BAN WS6's Avatar
Thanks for the replies guys, I was just a dumbass. Turns out the back brakes needed to be replaced. The rotor I did replace was just a bit warped and probably didn't have to be replaced, but it is now so **** it. Worse case scenario I just flushed 30 bucks down the toilet, I'll recover. Thanks again for responding.
Old 02-21-2008 | 08:34 PM
SixShooterCamaro's Avatar
Yeah take the calipers off and slip the rotor off... if it doesnt it might be corroded on so just hit it with a hammer until it breaks loose...
Brake cleaner works well when you are trying to remove the corrosion or rust
Old 02-21-2008 | 08:54 PM
BAN WS6's Avatar
I don't know if it's different ona Camaro but to get my rotors off I had to take the entire bracket that the caliper fit into to free up the rotor.
Old 02-21-2008 | 10:36 PM
95slvrZ28's Avatar
ORIGINAL: BAN WS6
Just a reminder, watch the language please.
SixShooter has the right idea to get the rotors off, but I usually go for a rubber mallet.
johncblackmon
10-13-2010 02:41 PM
gagger84
08-11-2009 11:26 AM
doug91rs
07-06-2009 10:10 PM
M.$tErNeR
01-02-2008 07:51 PM
JaySan
04-27-2007 10:44 AM
