Replacement part questions
I was wondering since I'm replacing my ignition coil and ignition control module if these are the right parts for it.
Link to parts
Link to parts
Well you never said what car you have? it also does not list the manufactures of the parts so even if you did tell use the year and engine of your car all we could do is go to their website and repeat what they say. 96 - 3800. If you knew the manufacture and part number you could check other sources like the manufactures website.
The price of these components very greatly depending on who the manufacture is. It seems risky buying when you do not know who makes it. If you buy the cheapest on RockAuto you are looking at $137 for the parts listed, GM OEM is more like $315. I am a fan of DELPHI since they make a lot of this stuff for GM and even use the GM part numbers. DELPHI is right around $200 for the same parts.
