Removing the LT1
#21
oh ok thats right you have a super camaro.. map or conection to it. test the evap to be sure. test fuel pressure. test thottle postion sensor. if you clear the ecm you will clear the codes. you can flash the codes on a 93 dont need a scanner.
http://www.shbox.com/1/dlc2.jpg
#22
Well we ended up getting the codes. Code 15 and code 26. We know code 15 is the coolant temp. sensor and code 26 is the Quad Driver module. But what we don't know is what the Quad driver module is. Any help on this one? Ha.
#26
Well, it runs fine, when we can get it to start. The alternator is going bad, so I'm replacing that soon. But the plugs became fouled when we first started getting it running. I'll end up replacing them as soon as the title gets back.
